Roller Shade Contoller SRSC-M01
did someone here manage to use aqara rolle shade Controller - for external Roller Shuters (mi ne ar plastic 2m² → 95cm wide and 2m high.) ? its 8Nm … are they reliable? manual rolle shuter have hexgonal pipe… i only manege to find 50mm found one with proper adapters.
The Aqara Smart Roller Shade Controller is rated for a maximum torque of 8N·m and a maximum load of 30kg. It’s designed for a 35mm pipe diameter as standard, but you mentioned your manual roller shutter uses a hexagonal pipe, and you’ve found adapters for 50mm. In terms of curtain size, your 2m² plastic shutter (95cm x 2m) should generally fall within the controller’s rated capacity, but always ensure the total weight doesn’t exceed 30kg, as that’s the key limiting factor.
@beno.zidaric The Aqara Roller Shade Controller has a torque capacity of 8N·m [“content_id”:1, “content_id”:6] and a maximum load of 30kg [“content_id”:4, “content_id”:6], which may be relevant to your 2m² plastic roller shutters. However, the reference information doesn’t specifically address external use, compatibility with hexagonal pipes, or adapter details.
It would be great to hear from other community members who have similar setups—feel free to share your experience if you try it out! If you have further questions, you can also check the app for more details or reach out to customer service if needed.
For any specific compatibility concerns, consider contacting the Customer Service Team via the Aqara Home App (Profile>Help&Feedback>Customer Service) or scanning the QR code:
for efficient support. If you don’t have an Aqara Home account, click here to create a ticket.
@beno.zidaric It’s great to see you exploring using the Aqara Roller Shade Controller for your external roller shutters! From the available information, the Aqara Roller Shade Controller (like the TA model) has a torque capacity of 8N·m and a maximum load of 30kg , which might be sufficient for your 2m² plastic shutter, but the reference information doesn’t specifically cover external use or compatibility with hexagonal pipes and 50mm adapters.
Reliability can vary based on installation and environment, but the controller supports features like slow start/stop which may help with smooth operation. Since your setup involves specific details (external use, adapter fit), it might be helpful to hear from other community members who have similar experiences—feel free to share updates if you try it out!
If you run into issues with compatibility or installation, you can also reach out to customer service for more tailored guidance.
Hope this helps, and looking forward to hearing how it goes!
@beno.zidaric It’s great to see you exploring using the Aqara Roller Shade Controller for your external roller shutters! From the available information, the Roller Shade Controller has a torque capacity of 8N·m and a maximum load of 30kg , which might align with your 2m² plastic shutters. However, the reference information doesn’t specifically mention compatibility with external use or hexagonal pipes, nor does it detail adapter fitments for 50mm setups.
Reliability can vary based on installation and usage, but the product does feature slow start/stop functionality , which helps with smooth operation. If you’ve found a suitable adapter, it might be worth testing—though do ensure the installation is secure.
Have other community members tried similar setups? Your experience could be really helpful for others! If you run into specific issues, feel free to share more details. For official support on adapter compatibility, you can reach out to customer service via the Aqara Home App (Profile>Help&Feedback>Customer Service).
