Got two of the roller shade Chinese version, and managed to link them manually with the hub. Can see the devices charging status changes and battery level from the apple homekit. Any tips for troubleshooting?!
@kalaparamasicam It sounds like you’ve successfully linked your Roller Shade E1 with the hub and can view some statuses in Apple HomeKit, but you’re facing issues with control. Here’s a set of troubleshooting steps that might help:
Check Compatibility and Pairing: Ensure that your Roller Shade E1 is fully compatible with HomeKit. You might want to double-check the product packaging or Aqara’s official website for the “Works with Apple HomeKit” label. Also, ensure that the device is properly paired with Apple Home.
Wi-Fi and Network: Make sure your Aqara devices and the HomeKit hub (like your iPhone, iPad, or HomePod) are on the same Wi-Fi network. A stable connection is crucial for proper functionality.
HomeKit Limitations: Some features might not be fully supported by HomeKit. You can check the Aqara app for any additional settings or functionalities that might be available outside of HomeKit.
Re-add the Device: If the issue persists, try removing the Roller Shade E1 from the Apple Home app and then re-add it. This can often resolve connectivity issues.
Reset the Aqara Hub: As a last resort, consider resetting the Aqara hub and re-pairing it with both the Aqara app and Apple Home. Follow the reset instructions provided in the Aqara Home app or the device manual.
If these steps don’t solve the issue, you might want to contact Aqara’s customer service for more in-depth support. I hope this helps, and feel free to share your progress or further questions with the community!
Thank you, will give a try with these steps in the weekend
@kalaparamasicam You’re welcome! Take your time, and I hope the steps help resolve the issue. If you encounter any further challenges or have any additional questions, feel free to reach out to the community. We’re here to help!
