Hey everyone, I wanted to share my recent experience with integrating my smart lighting system using Hubitat’s Rule Machine. It’s been a bit of a learning curve, but I’ve managed to get everything working smoothly!
I started by setting up some basic automation rules for my morning and evening routines. The goal was to have my lights turn on automatically at sunrise and off at sunset. However, I ran into an issue where the ‘wait for’ events weren’t completing as expected. After some troubleshooting, I realized that the problem was with how I was handling the dimmer switches. I had tried treating them as both switches and dimmers, but neither approach worked initially.
What finally solved the issue was ensuring that all devices were properly configured in the Hubitat app. I had to make sure that each device’s settings matched how I wanted them to behave. For example, setting dimmers to ‘0’ instead of just turning them off made a big difference. It was a small tweak, but it made everything work perfectly!
I also wanted to mention how impressed I am with Hubitat’s support community. When I was stuck, I reached out, and someone suggested checking the logging info. That was the key to identifying the problem quickly. It’s amazing how a little guidance can make such a difference.
For anyone else working on similar projects, my advice is to start simple and test each rule thoroughly before adding complexity. Also, don’t hesitate to use the logging feature—it’s incredibly helpful for troubleshooting. Happy automating everyone! ![]()
