I run an Aqara doorbell (SVD-C02) purely on batteries and it has been problem-free. The indoor chime sits in the house and is powered over USB-C. HomeKit works flawlessly, and I also have the doorbell running in Home Assistant. It responds quickly when I access it, the picture is great and night recordings are good too.
One thing could be better: the speaker - guests at the door often can’t make out what I’m saying. There is an optional power supply if I ever want to hardwire it.
Curious how others power their doorbells - how has battery operation worked for you compared with wired power?
@jbalm0 Hi there! Thanks for sharing your experience with the Aqara doorbell (SVD-C02) and your hybrid HomeKit/Home Assistant setup. It’s always great to hear from community members who are actively exploring different power configurations and integrations.
Regarding your question about battery versus wired operation, here are a few insights based on common user experiences:
Battery Life Considerations
When running on batteries, the device enters a low-power mode and sleeps until triggered, which helps conserve energy. However, several factors can impact longevity:
HomeKit Integration: If connected to HomeKit, the doorbell may record video more frequently when motion is detected, which can consume more power compared to using it solely in the Aqara Home app.
Detection Settings: A shorter loitering detection interval can lead to more frequent triggers, shortening battery life.
Signal Strength: If the doorbell is far from the repeater (more than 5 meters) or faces wireless interference, it may increase transmission power, leading to higher consumption.
Battery Type: Using high-quality LR6 AA batteries with a capacity of at least 2900 mAh is recommended. Mixing old and new batteries or using non-1.5V batteries can negatively affect performance.
Power Saving Mode
If you find the battery drain too fast, enabling Power Saving Mode can be very effective. In this mode, the PIR (motion) detection is turned off, and the doorbell is primarily triggered by the button press or remote viewing, which can significantly extend battery life.
Wired vs. Battery
Wired power ensures the doorbell is always active and does not enter sleep mode, providing consistent performance without battery worries. However, battery operation offers greater flexibility in placement and is ideal for renters or locations without existing doorbell wiring, especially with the backup power strategy many models now feature.
It sounds like your setup is working well overall! Have you considered adjusting the motion detection sensitivity or interval to see if it helps with any battery concerns, or are you happy with the current battery lifespan?
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
