S100 keeps falling off from homekit
I have multiple aqara products and hubs i have 2 M3 hubs with the latest firmware and installed a new s100 touch screen switch, i have it setup in the aqara app and in homekit I keeps dropping from home kit. I have a home pod and aqara m3 appx 10’ away. i keep reconnecting it but I’m in a loop with this happening in the app its showing device cannot be detected and unable to connect to matter device, ( i installed 2 and sent one back already. it was doing the same thing) also the wireless switches are useless in an apple home setup. for a 90 dollar switch i should be able to turn other switches in homekit on an off, instead you have to go down a rabbit hole of shortcuts to get it to work, only to have it not work the next day… i gave up on it… it shouldn’t work this way, just lik ethe U100 doorlocks always fail becasue the binding fails. i was told to move my door locks closer to the hub…) why should i keep or buy any other products when they don’t stay connected and the usability of most features don’t work in a apple home environment??? how do i keep the S100 connected and is there going to be a firmware update that actually makes this a usable product
@Raptor7 Hey there! Totally get the frustration—looping reconnection issues with a premium switch like the S100 would drive anyone up the wall, especially when you’ve already swapped hardware once.
For the S100 repeatedly dropping from HomeKit and showing “unable to connect to matter device,” a few things worth checking based on similar Matter-related stability issues:
  • Thread network consistency: Since you have two M3 hubs, double-check that both are on the same network/SSID and running the latest firmware. Multiple Matter controllers on different networks can cause devices to flip-flop or drop off entirely. Given your M3 and HomePod are only ~10’ apart, this shouldn’t be a range issue, but network segmentation sometimes sneaks in with multi-hub setups.
  • Power cycling the Thread border routers: Try unplugging both M3s and your HomePod, wait a solid 2 minutes, then bring them back online one at a time. Matter/Thread can get into weird states where devices cling to a suboptimal router.
  • The “re-add” dance: If the above doesn’t stick, removing the S100 from both Aqara and HomeKit, then re-pairing it fresh sometimes clears out stale Thread credentials. Not ideal as a permanent fix, but it can surface whether this is a credential sync issue vs. deeper firmware instability.
On the wireless switch/HomeKit usability and broader Apple Home gripes—you’re not wrong that the current Shortcuts workaround for wireless bindings is clunky. For product-level feedback like that (and to properly log the S100 stability pattern for the team), the most direct path is:
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket.
Worth mentioning in that ticket: you’ve reproduced this across two S100 units, have dual M3s, and that the Aqara app itself flags “device cannot be detected”—that pattern should help them escalate whether it’s a known Thread/Matter edge case with the S100 firmware or your specific network topology.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
So the answer to the s100 dropping off every night is my Unfi network scanning channels every night for congestion and changing channels. The log showed the s100 dropping off every night between 3:05 and 3:09 am. Which corresponds with the channel scan starting at 3:00 am. Aqara needs to fix this. This 100 switch should be able to stay connected when the 2.4ghz channel changes. The 35 dollar Tapo s515 have no problem with it. I’ve turned off optimization at 3am on my network.
Having the same issue with two switches suggests it may be worth asking Aqara support to investigate the Matter connection. It would also help to know if other users are experiencing this with Apple Home. Hopefully, Aqara can identify the cause and address it in a future firmware update.
Same issue here. W200 and two Apple TVs acting as Matter over Thread border routers. S100 adds to Aqara and Apple Home no problem, then as soon as I try to use any of the Wireless Switches immediately no response in Apple Home until I remove and re-add it.
