Subject: Scene and Signal Sync “Limited Trial” terms (Hub M2, Home Assistant)
Hello,
I’m using Scene Sync on my Aqara Hub M2 to expose two Aqara scenes to Home Assistant as virtual switches. The scenes turn the sirens on and off on two G5 Pro cameras, and I plan to trigger them from my home alarm system.
In the Aqara Home app, under Profile > Connect to Ecosystems > Home Assistant > Scene and Signal Sync, the feature is labeled “Limited Trial.” I can’t find any terms for it in the app or on your website. Before I build my alarm around it, I’d like to understand the following:
- What does “Limited Trial” mean for this feature? Is it limited by time, by number of scenes or signals, or both?
- If it’s time-limited, when does my trial end? Does it run per account, per hub, or per synced scene?
- What happens when the trial ends? Do scenes and signals that are already synced keep working, stop working, or get removed from Home Assistant?
- Will this become a paid feature or subscription? If so, what will it cost?
- Do the same trial terms apply to the Matter entry under Connect to Ecosystems, or only to the Home Assistant entry?
My setup:
- Aqara Hub M2, firmware 4.5.60, set as the scene execution device and shared to Home Assistant over Matter
- Two Aqara G5 Pro cameras
- Region: United States
Thanks for your help.
