Hey everyone, I wanted to share a solution I found to keep my Home Assistant hub running smoothly. I’ve been dealing with a slowdown issue where my automations would take 10-15 seconds to run, even though device controls remained fast. This was pretty frustrating, especially after trying various troubleshooting steps without success.
After some research, I discovered that scheduling regular hub restarts could be a reliable workaround. I decided to set up a nightly reboot to ensure everything stays responsive. For anyone else dealing with similar issues, here’s how I did it:
- Identify the Cause: I noticed the slowdown happened every couple of days, likely due to accumulating processes or memory leaks, especially since I have several custom-coded devices and integrations.
- Set Up the Reboot: I used Home Assistant’s built-in automation to trigger a reboot at 2 AM every day. This ensures the hub is fresh without disrupting my daily routine.
- Testing: I monitored the system for a week, and the automations are now running smoothly again. It’s a simple fix that makes a big difference!
If you’re experiencing similar performance issues, I’d recommend giving this a try. It’s a hassle-free way to maintain reliability without deep dives into code or configurations. Happy automating! ![]()
