I’ve been using SD cards for my Home Assistant setup for quite some time now, and I wanted to share my experience and some tips that might help others. SD cards have often been criticized for their reliability, but in my case, they’ve been performing exceptionally well. Let me walk you through my setup and some best practices I’ve adopted.
My Setup
I’m running Home Assistant on a Raspberry Pi 4 with an SD card as the primary storage. I’ve been rotating through a set of four identical 32GB SanDisk A1 SD cards for about four years. The setup is modest, with timed events and event-driven automations. All components—automation, user interface, and mobile app—respond in under a second. Log and history data retention is set to default, and I have over a year’s worth of data stored. Disk space usage remains stable at around 22%, which I believe contributes to the longevity of the SD cards.
Backup and Recovery
One of the key reasons SD cards work well for me is the robust backup strategy I’ve implemented. I perform monthly backups, upgrades, and system tests. In the unlikely event of an SD card failure, I can restore the system within minutes using a backup SD card. The data loss risk is minimal, as I use a Google Drive Backup addon for weekly backups. This setup ensures that even in the worst-case scenario, I lose no more than 30 days of data, which is manageable for my needs.
Why SD Cards?
SD cards offer several advantages that make them a great choice for many users:
- Simplicity: No additional cables, USB hubs, or power supplies are needed, reducing potential points of failure.
- Cost-Effectiveness: High-quality SD cards are relatively affordable, making them an accessible option.
- Ease of Use: They are widely available and easy to replace.
- Performance: For setups with modest storage and performance requirements, SD cards deliver reliably.
Tips for Reliable SD Card Usage
- Regular Backups: Implement a consistent backup schedule and test your backups periodically to ensure they work as expected.
- Monitoring: Keep an eye on disk usage to prevent unexpected fill-ups, which can lead to system instability.
- Quality Cards: Invest in reputable brands known for their reliability and durability.
- Power Management: Use a UPS for your Raspberry Pi and networking gear to protect against power outages, which are a common cause of SD card corruption.
Conclusion
SD cards are a viable and reliable option for many Home Assistant setups, especially when paired with a solid backup strategy. They might not be the best fit for every scenario, but for those who value simplicity and cost-effectiveness, they are hard to beat. If you’re considering SD cards for your setup, I encourage you to explore the options and find the solution that best fits your needs.
Happy automating! ![]()
