Seamless Migration and Integration: My Experience with Hubitat, HOOBS, and Lutron
I recently undertook the migration from my Hubitat C5 to C8 and wanted to share my experience, as it was surprisingly smooth! The process was straightforward, and I couldn’t be happier with the outcome. Here’s a quick rundown of my setup and the steps I took:
My Setup:
  • Hubitat C8 as the main hub
  • HOOBS for integrating a few Wi-Fi devices and retaining voice control
  • Lutron Pro2 Hub for my Caseta devices
  • A mix of Z-Wave Plus, Lutron Caseta, and a few Zigbee devices
Migration Process:
  1. Preparation: I followed the official migration guide meticulously. I paused the Hubitat Maker API gateway on HOOBS, shut down my C5, and removed its IP address reservation on my network router.
  2. C8 Setup: After connecting the C8, I let it acquire an IP address, registered it, and restored my cloud backup. I then set up a static IP for the C8, mirroring my previous setup.
  3. Reintegration: I restarted the C8, powered back up my Lutron Pro2 Hub, and re-enabled the necessary LAN integrations. Everything fell into place without a hitch!
Results:
  • The migration took less than 20 minutes!
  • All devices, including locks and motion sensors, are functioning perfectly.
  • Voice control via iPhones and Apple Watches works seamlessly.
  • I noticed improved response times for some devices, which is a delightful bonus!
Tips for Others:- Backup Early: Ensure you have a solid cloud backup before starting.
  • Static IPs: Manage IP reservations carefully to avoid conflicts.
  • Test Integrations: After migration, double-check all integrations, especially voice controls and third-party apps like HOOBS.
I’m thoroughly impressed with Hubitat’s support and the C8’s performance. If you’re considering an upgrade, I highly recommend it! :rocket:
