Hey everyone, I’m reaching out to the community to see if anyone has encountered and resolved an issue I’m currently facing with my smart home setup. I’ve been experimenting with creating automation rules to control my garage lights, and while the concept works, there’s a noticeable delay that I’d like to eliminate.
Here’s a bit about my setup:
- Garage Lights: These are controlled via a Z-Wave switch, which I’ve confirmed is directly connected to the hub with a strong signal.
- Motion Sensors: I have three motion sensors strategically placed to cover all entry points.
- Automation Rule: The rule is designed to turn on the garage lights if any of the motion sensors detect movement.
The issue I’m experiencing is a consistent 5-second delay between the motion sensor detecting movement and the lights turning on. From the logs, it appears that the rule itself triggers immediately, so I’m confident the problem isn’t with the Z-Wave mesh or the sensors themselves.
I’ve tried a few troubleshooting steps:
- Checked Z-Wave Connection: Confirmed that the garage light switch has a strong and stable connection.
- Reviewed Logs: The logs show that the rule fires without delay, so the issue must be elsewhere.
- Updated Firmware: Ensured that all devices are running the latest firmware.
Has anyone else encountered a similar delay? If so, how did you resolve it? I’m particularly interested in understanding if this is a common issue with certain types of automation rules or if there’s a configuration tweak that can help.
Any advice or insights would be greatly appreciated! Let’s see if we can get those garage lights to respond as quickly as they should. ![]()
