Seeking Integration Tips: Tado Thermostats with Central Heating
Hi everyone,
I’ve recently installed Tado radiator thermostats in my home, and while they’re working well individually, I’m trying to integrate them seamlessly with my central heating system. The challenge is that the Tado thermostats only function when the central heating thermostat is also active. I’ve managed to create an automation that syncs the temperature settings, but I was hoping there might be a more streamlined solution or a pre-existing blueprint for this setup.
I’ve spent quite a bit of time searching for resources, but it seems like this might not be a common configuration. I’m wondering if I’m using the right search terms or if there’s a specific approach I haven’t considered. Has anyone else successfully integrated Tado thermostats with their central heating? Any tips or shared blueprints would be incredibly helpful!
Looking forward to hearing your experiences and ideas. Thanks in advance for your support!
Best regards,
