Sensor inundacion aqara
Good morning, I have a G5 camera and I have a temperature sensor and a flood sensor connected to it. The temperature sensor converts to a MATTER signal, but the flood sensor does not. Is this normal?
Hello @juan_navaja
Which system are you connecting sensors to via Matter Bridge? Your system may not support leak sensors because it’s using an out-of-date Matter SDK. Update your Matter Controller to the latest version, as well as the Aqara hub.
Good morning, I connect it to a 1home system that converts Matter devices to KNX. I connect the PoE G5 camera to it via an Aqara hub, and I have connectors for temperature, smoke, and water sensors. It only recognizes the temperature sensor; it doesn’t detect the others.
