Serial Settings Reset Issue on Vera Edge
Hi everyone,
I’ve been working with my Vera Edge and a custom serial gateway using an Arduino Uno. Everything was running smoothly until I had to unplug the power supply for maintenance. Upon reconnecting, I noticed that the serial port settings on my Vera Edge had reverted to their default configurations. This means I have to manually reconfigure the settings every time there’s a power interruption, which is quite inconvenient.
I’m wondering if this is a known issue or if there’s a workaround to prevent the settings from resetting. Is there a way to make the Vera Edge retain its serial port configurations even after a power cycle? I’ve checked the Vera Edge’s settings and the Arduino code, but I can’t seem to find a solution.
Any advice or suggestions would be greatly appreciated! Thanks in advance for your help.
Best regards,
