Set an automation based on comparing 2 values from different sensors
Hello
Does anyone know how to set an automation based on a comparison between two devices.
Example : turn on switch if P1-1 sensor humidity is greater than P1-2 sensor humidity
This should be possible with Home Assistant, but as far as I know, it is currently not possible with the Aqara Home app or the Apple Home app.
Something called Aqara Studio is still in development. You’ll be able to do this once it’s released. In the meantime, you can use Home Assistant like @JohnD mentioned.
Great idea.
