Setting Up a Manual HA Development Environment on RPi5: Tips and Tricks
Hi everyone,
I recently decided to set up a manual Home Assistant development environment on my Raspberry Pi 5, and I thought I’d share my experience in case it helps anyone else. While the process was a bit involved, it was definitely worth it to get everything running smoothly.
First off, I installed Raspberry Pi OS (64-bit) Lite following the official instructions. However, I quickly realized that the default Python version (3.11) wasn’t sufficient for Home Assistant Core, which requires at least Python 3.12. So, I had to download and install Python 3.12.4 from source. Here’s a quick rundown of the steps I took:
bash
Download the Python source
wget https://www.python.org/ftp/python/3.12.4/Python-3.12.4.tgz
Install build tools
sudo apt update
sudo apt install build-essential zlib1g-dev libncurses5-dev libgdbm-dev libnss3-dev libssl-dev libreadline-dev libffi-dev libsqlite3-dev
Configure, build, and install Python
tar -xzvf Python-3.12.4.tgz
cd Python-3.12.4/
./configure --enable-optimizations
sudo make altinstall
After Python was set up, I moved on to installing the Home Assistant development environment manually. I followed the instructions from the official documentation, but there was a small tweak I had to make. The setup script uses python3 -m venv venv, which didn’t work as expected. I modified it to use the newly installed Python 3.12 by changing it to /usr/local/bin/python3 -m venv venv. I made sure to revert this change after the installation was complete to avoid any future issues.
One thing I found particularly helpful was the community’s willingness to share tips and tricks. For instance, someone mentioned using a cron job to handle time-based triggers, which I implemented successfully. It’s amazing how much you can learn from others’ experiences!
I also came across some great resources for troubleshooting common issues. For example, if you’re dealing with devices that are showing as ‘unavailable’ in Home Assistant, checking the device’s IP address and ensuring it’s correctly configured can make a big difference. Additionally, I found that using the tuya.pull_devices and tuya.force_update services from the developer tools can help refresh device states if they’re not updating properly.
If you’re considering setting up your own development environment, I highly recommend starting with the Raspberry Pi. It’s a fantastic platform for experimenting with Home Assistant, and the community support is incredible. Just remember to take it one step at a time and don’t hesitate to ask for help if you run into any roadblocks.
Happy coding!
Best regards,
