Setting Up Anavi Miracle Controller with ESPHome: A Smooth Process
I’ve been diving into the world of ESPHome lately, and I must say, it’s been an incredible journey! I recently purchased the Anavi Miracle Controller along with some sensors—a MPU-6050 for motion and a SHT40 for temperature and humidity. My goal was to set up a fully functional IoT hub using ESPHome, and I’m thrilled to share my experience with you all!
Initially, I faced a bit of a challenge with the sensor connections. I had only one sensor cable at the time, so I started with the MPU-6050. After some research, I found a helpful .yaml template that I could modify for my setup. However, I ran into an issue with the FastLED library not working out of the box. But thanks to the ESPHome community, I discovered that switching to the neopixelbus platform solved the problem beautifully!
Here’s a snippet of my .yaml file for reference:
yaml
light:
  • platform: neopixelbus
    variant: WS2812
    type: GRB
    pin: GPIO12
    num_leds: 10
    effects:
    • addressable_rainbow:
      speed: 10
      width: 50
    • addressable_color_wipe:
      name: Color Wipe Effect
      colors:
      - red: 100%
      green: 100%
      blue: 100%
      - red: 0%
      green: 0%
      blue: 0%
One thing I wanted to highlight is the importance of proper documentation. ESPHome’s official documentation was a lifesaver, guiding me through the firmware flashing process and sensor integration. I also found that using the Arduino IDE alongside ESPHome made the process smoother, especially when tweaking the firmware for additional sensors.
I’m absolutely thrilled with how everything is coming together. The MPU-6050 is responding perfectly, and once I get the SHT40 connected, I’ll be able to monitor both motion and environmental conditions in real-time. The LED effects add a nice visual touch, making the setup both functional and aesthetically pleasing.
If anyone out there is considering the Anavi Miracle Controller, I highly recommend giving ESPHome a try. It’s a powerful tool with a vibrant community backing it up. I’m already brainstorming ways to expand this setup—maybe adding more sensors or integrating it with my existing smart home ecosystem.
Happy tinkering, everyone! :rocket:
