Setting Up Pi-hole Switch in Home Assistant: A Smooth Experience
I recently decided to integrate my Pi-hole into Home Assistant to have better control over my network’s ad-blocking capabilities. After some research, I came across a detailed guide on creating a switch for Pi-hole in Home Assistant. The process was surprisingly straightforward, and I wanted to share my experience in case others are considering the same setup.First, I had to configure the Pi-hole integration in Home Assistant. This involved adding the necessary sections to my configuration.yaml file. I made sure to replace the placeholder IP address with my Pi-hole’s actual IP and set up the API key as instructed. It was a bit nerve-wracking at first, but everything worked out smoothly.Next, I set up a command-line sensor to monitor the status of Pi-hole. This was essential because the default integration doesn’t provide a direct status indicator. The sensor uses a curl command to fetch the status from Pi-hole’s API, and it updates every 10 seconds. I found this interval to be a good balance between real-time updates and resource usage.Creating the switch itself was the highlight of the process. Using a template switch, I was able to control Pi-hole’s enabled state directly from the Lovelace interface. The switch uses the Pi-hole’s enable and disable services, and I set the disable duration to 12 hours by default. This means I can easily block ads for a specific period without manually re-enabling Pi-hole later.One thing I noticed is that the switch’s state might flicker occasionally due to the sensor’s scan interval. However, this doesn’t affect functionality and is more of a visual quirk. After a few minutes, the switch stabilizes, so it’s not a major issue.I also experimented with different icons and card layouts to make the switch stand out in my dashboard. The mdi:pi-hole icon is perfect and adds a nice touch of customization. I ended up using a simple button card, which provides a clean and functional interface.Overall, this integration has been a great addition to my Home Assistant setup. It gives me peace of mind knowing that I can control ad-blocking with just a tap, and it’s fully integrated into my smart home ecosystem. If you’re looking to enhance your network management, I highly recommend giving this a try!
