Hi everyone, I wanted to share my experience setting up scheduled restarts and updates in Home Assistant. This has been a game-changer for me, especially since I rely heavily on custom integrations that often require a restart to function properly. Here’s how I did it:Why I Needed This I run Home Assistant on Home Assistant Operating System (HA OS) and use HACS for custom integrations. While these integrations add a lot of functionality, they sometimes cause instability if not managed properly. I wanted a way to handle updates and restarts without manual intervention, ensuring my system stays reliable and up-to-date.What I Did 1. Scheduled Restart Automation I set up an automation that restarts Home Assistant at a convenient time (overnight on weekends for me). This ensures that any pending updates or changes are applied without disrupting my daily routine. - I created two input helpers: one for enabling the reboot (input_boolean.reboot_enable) and one for setting the time (input_datetime.reboot_time). - The automation checks if the reboot is enabled and triggers a restart at the specified time. 2. Scheduled Core Update Automation Updating the core of Home Assistant can be risky, but I wanted to automate it while minimizing potential issues. - I set up another automation that performs a full backup, waits for it to complete, and then updates the core. - This automation is triggered at a set time and includes checks to ensure it only runs when enabled. Lessons Learned - Backup Regularly: Always ensure you have a recent backup before making any changes. - Read Patch Notes: Before enabling updates, review the patch notes to understand what changes are being applied. - Test in a Safe Environment: If possible, test updates in a controlled environment before implementing them in your main setup. Tips for Others - If you’re new to automations, start simple and gradually build up your setup. - Use the automation editor in Home Assistant to visualize and test your automations before deploying them. - Consider setting up notifications to alert you when updates or restarts are initiated or completed. This setup has greatly improved my system’s reliability and reduced the time I spend on maintenance. I hope this helps someone else looking to streamline their Home Assistant experience!
