Setting Up Shelly PRO 3EM Without Internet: A Step-by-Step Guide
Hi everyone, I recently purchased the Shelly PRO 3EM and decided to set it up without an internet connection. I thought this might be a bit tricky, but it turned out to be manageable with a little research and patience. Here’s how I did it:
  1. Physical Setup: First, I connected the Shelly PRO 3EM to my home’s electrical system. It was straightforward—just a matter of plugging it into the correct terminals in my electrical panel. I made sure to follow all safety precautions and double-checked the wiring to ensure everything was secure.
  2. Local Configuration: Since I didn’t have internet access at the time, I used my smartphone to connect directly to the Shelly device’s Wi-Fi network. This was a bit confusing at first, but I found the SSID and password printed on the device itself. Once connected, I opened the Shelly app and followed the on-screen instructions to configure the device locally.
  3. Manual Pairing: The app guided me through pairing the device without needing an internet connection. I was able to set up basic monitoring functions and even configure some alerts for power usage. It wasn’t as feature-rich as the cloud-based setup, but it got the job done for my initial needs.
  4. Post-Installation Tips: After setting it up, I realized the importance of regular checks. I created a simple checklist to monitor the device’s performance and ensure it’s functioning correctly. I also plan to explore more advanced settings once I have a stable internet connection.
This experience taught me that even without internet, modern smart devices can be configured and used effectively. It’s all about understanding the device’s capabilities and being resourceful. I hope this helps anyone else looking to set up their Shelly PRO 3EM in an offline environment. Happy tinkering! :rocket:
