Several Aqara hubs in one home: how do you choose a sensor’s parent hub?
A recent multi-hub setup question has an M3 plus other hub-capable devices across two floors, while many sensors are currently on the M3. What should determine a Zigbee child device’s parent hub when more than one is available?
I would compare the radio reliability at the sensor’s actual location, which hub its automations or Matter bridge rely on, and what stops working if that hub is offline. A single central hub may be easier to manage, but I would not assume it gives the best radio path everywhere. Before moving anything important, I would record the current pairing and test one low-consequence sensor.
For those using multiple Aqara hubs, what evidence made you keep a sensor on one hub or move it to another? Did moving it affect automations or Matter exposure? Aqara’s guidance on a supported migration path would also help.
I also mostly look for radio signal strength but am trying to migrate everything to Thread over time as it forms a mesh and is this more failure proof
Same! I just pair accessories directly to Apple Home nowadays and try to avoid using too many extraneous hubs. Thread has been working very well so far for my smarthome.
Hi! Personally, I’ve set up a reliable mesh network for my hubs using a router. This means I don’t have to worry about which hub a device connects to—the only exception is for critical leak sensors, which connect directly to the hub (bypassing any repeaters).
