Share One Smart Home Tip for Beginners and Earn Points!
Hi everyone!
Our Aqara Presence Multi-Sensor FP400 Exclusive Trial is now underway. If you need more points to apply for the trial, this Points Boost activity is a quick and easy way to earn them!
What advice would you give to a smart home beginner?
Think back to when you first started building your smart home. Share one tip you wish you had known earlier.
Need some inspiration? You could tell us:
  • A simple setup or automation that greatly improved your smart home experience
  • A mistake you made—and how beginners can avoid it
  • Which device category you recommend starting with
  • One small change that made your setup more reliable or convenient
Your advice does not need to be technical or lengthy. A practical tip based on your real experience may be exactly what another community member needs!
How to Participate
Create a new topic sharing your tip and include the hashtag StarterTips.
Photos and videos are very welcome.
Rewards
We will select 3–5 lucky participants on each of the following dates:
  • August 12
  • August 14
  • August 17
Each selected participant will receive 20 points.
If your post is especially helpful and gets featured by the forum team, you will receive an additional 20 points!
Event Period
Submit your topic by August 17 to participate.
We look forward to reading your advice—and helping more smart home beginners get off to a great start. What is the one tip you wish someone had shared with you? :bulb:
If I could give one piece of advice to someone starting their smart home journey, it would be: think long term and choose an ecosystem that can grow with you.
When I started, I bought a mix of devices from different brands because they were on sale or looked interesting. Everything worked at first, but as my setup grew, managing multiple apps and dealing with compatibility issues became frustrating.
Looking back, I wish I had started with Aqara and built around a single ecosystem from the beginning. Aqara offers a wide range of devices, from sensors and switches to locks and cameras, making it easy to expand over time without having to replace what you already own.
The biggest improvement to my smart home came from simple automations using door and motion sensors. For example, having lights turn on automatically when entering a room sounds basic, but it’s one of those things you use every day and quickly stop thinking about because it just works.
Another tip is to start with sensors rather than fancy gadgets. Sensors are relatively inexpensive, but they enable countless automations that make your home feel truly smart instead of just remotely controlled.
My final advice: keep things simple in the beginning, focus on reliability, and build a scalable foundation. It’s much easier to add new devices later than to rebuild an entire system because your first choices didn’t fit together.
Keep things simple and stay away from anything Google or Amazon owned. The Company Business model matters. YOU and your activity should not be the product being sold.
Smart Bulbs are great with Lamps
Smart Switches are great for everything else
Hubs are your smart home friend
Do NOT over load your WiFi (you will regret it)
StarterTips
My tip: automatic laundry room lighting with a motion sensor
When I first started my smart home, I added a motion sensor and a smart bulb (both Aqara), connected through an Aqara Hub, in my laundry room, and it turned out to be one of the simplest but most useful things I set up.
The automation is basic: the light turns on when motion is detected, and turns off automatically after 15 minutes of no movement. That’s it — no complicated routines, no manual scheduling.
What surprised me was how much friction it removed from everyday life. I used to walk in with a laundry basket, fumble for the switch with my hands full, and forget to turn the light off half the time. Now I just walk in and the light is already on, and I never have to think about turning it off again.
My advice for beginners: don’t overlook small, “boring” spaces like laundry rooms, closets, or hallways when picking your first automation. They’re low-stakes (nothing bad happens if the timing isn’t perfect), cheap to set up, and the payoff in daily convenience is surprisingly high compared to more complex automations. It’s a great first project to learn the basics before tackling anything bigger.
I would suggest stick with more established brand that integrates with all platforms, offer several categories. I would recommend starting with your most important use cases and build from there. Don’t get caught up in all the gimmick things you see online by many tech geeks, It really makes your house look and feel cheap.
Regarding the WiFi, just make a dedicated 2.4 GHz for all you IoT devices and that will keep your WiFi from clogging. Best thing I ever did.
First tip: estimate your own skill level rightfully.
Have you some experience with home automation, with different ecosystems, with gadgets from that brand you want to step in? Or are you a complete novice?
Second tip: according to your skill level choose the right ecosystem, the right devices and don’t start with the most complex automation or a highly networked setup of multiple devices of different types. Start with a simple product to become familiar with the specific characteristics, with the way to setup and to bind to your own ecosystem and how to program automation.
Third tip: write down all questions you encounter during your planning, during buying, during setup, during programming and seek help e.g. here in the forum! Don’t be shy to ask, don’t hesitate, there are almost no dumb questions if you ask politely for help. For instance, have you ever thought about the need of a hub for your planned home system? Which one do you need? Do you need one at all?
Fourth tip: read, listen and watch
Read the manual(!!), read here in the forum, listen to advices or tutorials given e.g. here and watch videos e.g. from Aqara directly or some on YouTube. Which device matches best your needs, how it looks in real (remember there are very clean and sleek gadgets, there are very geeky gadgets, there are very ugly gadgets,… ask your love one in your household about her/his opinion!! You won’t be the first one who is not allowed to install a smart device in your home! :weary:) , how many of them do you need for achieving your goals, how much will this costs you in money and in time to install finally, how to install, how to program, where can I find help, who can I ask for help if I encounter problems?
The more you think about the above in advance the more time and trouble will you spare later!
P.S. one example for bad planning from my own experience.
I bought 2 G5 cameras only to encounter that the place I installed them was too high for proper detections of faces or cars. A clear case of too less reading before installing. My own fault.
As @mansfre stated, it’s always best to think ahead and invest in one ecosystem rather than trying to make everything work together. Yes, I know Home Assistant is a thing, but it can be clunky to set up fully. Sure, you might have more features available to you, but keeping it simple is always the best option.
One automation that I found to be awesome is the ability to link my door and window sensors to my thermostat. Before upgrading, I had to make several automations and conditions separately rather than having it be in two setups. This way, in the winter, when I open any of my windows, it pauses the AC, and when all windows are closed, it will turn it back on. Sounds simple, but trying to make the Aqara sensors talk to my old Ecobee, it was a pain to get right.
I also agree that sensors are a good start. You can always scale up from there :slight_smile:
My tip for smart home beginners:
  • start small and focus on useful automations instead of buying lots of devices at once.
  • Start with something simple like lights or motion sensors, learn how everything works,
    and then expand step by step.
A reliable smart home is better than a complicated one. :slightly_smiling_face:
Hi everyone!
I’ve been using Aqara devices for several years now, and I wanted to share a little automation I recently set up at home.
My Aqara Hub M3, along with all its child devices, is connected to my mini PC running Home Assistant via Matter.
I started using Home Assistant because I wanted to build more advanced automations from a desktop environment. It gives me much more flexibility than managing everything from a smartphone or tablet.
But my latest automation isn’t about lights, sensors, or smart home stuff… it’s about our newborn. :smile:
Our son is now one month old, and I wanted an easy way for my wife and me to keep track of his feedings, diaper changes, and bowel movements.
So I decided to use an Aqara Wireless Mini Switch and assign a different action to each type of press:
:point_right: Single press → Feeding
:point_right: Double press → Diaper change
:point_right: Long press → Bowel movement
Each press triggers a Home Assistant automation that records the event in our calendar. This means we can quickly check when he last ate, when his diaper was changed, or when he last had a bowel movement — without having to open an app and manually enter anything.
I have one Wireless Mini Switch in the bedroom and another one in the living room, so whichever room we’re in, the button is always within reach.
Everything is connected to the Aqara Hub M3 and exposed to Home Assistant through Matter.
I’ve also integrated the Hub M3 alarm system into Home Assistant through HomeKit, and I’m doing the same with several other parts of my smart home setup.
Honestly, this is what I love about Aqara devices: they’re simple, flexible, and can be used for things you don’t necessarily think of when you first buy them.
And yes… my wife is probably even happier with these automations than I am. :joy:
So, thank you Aqara! :heart:
StarterTips
My tip for smart home setup:
Pick your ecosystem.
When purchasing any new product make sure it is Matter compatible. This will ensure it can be integrated into any ecosystem.
Pick your protocol: zigbee/ Tread / WiFi
Zigbee is tried and tested and will be most stable. Would avoid WiFi enabled devices if possible.
Invest in a good hub: e.g M3 as this will form your base as you add devices down the line!
Smart bulbs offer more flexibility than smart switches when running automations. E.g ability to set colour temp and brightness.
Keep automations simple at first and add complexity as you become more familiar.
It takes time to setup an entire smart home so enjoy the learning process and expect some frustrations along the way!
My starter tips:
  1. Keep it Simple. Not everyone will like your smart home. Remember to keep the manual operations along with automations. My spouse is not a smart home fan and sometimes prefers the use of a dumb light switch instead of an automation. Happy Wife-Happy Life! :100:
  2. To start spend the money on a good quality hub. i.e. Aqara M3.
StarterTips
I remember my first automation as a beginner: motion-activated hallway lighting. Simple idea - walk in, light turns on. I set it up in an afternoon and felt like a genius.
Then reality hit. I’d set the “no motion” timeout to 30 seconds because I wanted it snappy. The problem? If I stood still for more than half a minute - folding laundry, reading a label, tying a shoe - the light would shut off on me. I ended up waving my arms around my own hallway like an idiot just to keep the lights on.
I almost gave up on automations entirely after that, thinking “this is more annoying than a light switch.”
The actual fix was embarrassingly simple: bump the timeout to 5-10 minutes, and if your sensor supports it, use a “luminance threshold” so it only triggers when it’s actually dark, not just whenever you walk by in daylight.
My tip: your first automation will almost always be too aggressive. Don’t judge the technology by your first settings - judge it by your third or fourth attempt, after you’ve tuned the timing to how you actually move through your home. The “aha, this is magic” moment comes right after the “why is this so annoying” phase, not before it.
Thanks for this opportunity Aqara ! Please sign me in !
Country: Romania, Europe
StarterTips
T biggest mistake I made when I first jumped into Apple Home was trying to automate everything right out of the box.
I got way too excited & bought a bunch of advanced sensors & tried to build complicated presence routines before I even had the basics down. Half the time my lights were doing weird things eapecially the fan, and nothing felt seamless.
If I could go back and tell myself one thing, it would be to start with smart lighting and keep it simple.
Begin with the basics: Grab some smart bulbs or a smart plug first. Being able to say “Hey Siri, turn off the living room light” or setting your entrance lights to come on at sunset gives you an instant win. It’s practical, and everyone in the house gets used to it right away.
Don’t rush into complex sensors & save the heavy-duty motion and presence sensors for later. Get your Wi-Fi and your Apple TV or HomePod hub running smoothly first so you actually have a solid foundation.
Build your smart home one small piece at a time. You’ll save yourself a lot of frustration and end up with a much more reliable setup!
Claude & HomeAssistant make creating automations a lot easier. It’s not perfect but can really help getting you started with creating advanced working automations.
When I first started smart home automations it was a door sensor here and camera there but I think the first step up the game for me was putting a vibration sensor on my dryer and a smart plug for my washer.
Both those Aqara devices allowed me to create automations where I was able to automate my laundry washer and dryer and make me start seeing tangible value from smart home tech.
So my advice if you have a dumb washer and dryer toss the above mentioned devices and start making your house work for you.
StarterTips
Think about what your home to do and work. Watch videos, read articles and ask people you know about their smart home. Reread the directions on a new product at least 5 times!! Lastly pick one platform ( Apple, Android , etc) and stick with it
I strongly recommend to establish a clear naming structure for all your devices. Check this out: Best Practices for Naming Your Smart Home Devices – Learned the Hard Way
