Shelly 1 Mini Gen3 and BLU Wall Switch 4 Integration Experience
I recently decided to upgrade my garage lighting system by integrating a Shelly 1 Mini Gen3 with a BLU Wall Switch 4. My goal was to control the garage lights wirelessly without relying on Wi-Fi, which isn’t available in that area of my home. Initially, I was a bit puzzled about how to connect these devices directly, as I couldn’t find any clear instructions in the Shelly app. After some research and experimentation, I discovered that it’s indeed possible to pair them using a direct connection method.
Here’s what I learned:
  1. Compatibility Check: Ensure both devices are compatible with each other. The BLU Wall Switch 4 supports Zigbee, which the Shelly 1 Mini Gen3 also uses, making them a perfect match.
  2. Pairing Process: The key was to put the Shelly 1 Mini Gen3 into pairing mode. I did this by holding down the reset button for about 10 seconds until the LED started flashing. Then, I simply pressed the pairing button on the BLU Wall Switch 4. The connection was almost instantaneous!
  3. Configuration: Once paired, I used the Shelly app to configure the settings. I was pleasantly surprised by how smooth the setup process was after the initial hurdle of finding the right pairing method.
  4. Performance: Since setting this up, the system has been working flawlessly. I can now toggle the garage lights with the wall switch, and the integration with my smart home system allows me to control them remotely as well.
If you’re looking to integrate Shelly devices with other brands, my advice is to check for compatible communication protocols and explore manual pairing options if the app doesn’t guide you through it. It’s a great way to expand your smart home setup without being limited by Wi-Fi availability.
I’d love to hear about others’ experiences with similar setups or any tips you might have for troubleshooting device integrations. Let’s keep the conversation going! :rocket:
