I’ve always been fascinated by the idea of seamlessly integrating technology into everyday life, and my recent experience with the Shelly 1 Mini has been nothing short of transformative. Let me share my journey and some tips that might help others looking to embark on a similar project.
The Challenge
I wanted to install smart lighting solutions in my home’s exterior, but the existing setup posed a challenge. My house has outdoor wall sockets installed in the insulation layer, which, due to the uneven and rough exterior wall, I was concerned about water ingress. This was crucial as I planned to use the Shelly 1 Mini to control my outdoor lamps.
The Solution
After some research, I decided to house each Shelly 1 Mini in a small IP65-rated enclosure. This tiny box provided the necessary protection against the elements. I drilled small holes for the cables and sealed them with a one-component polyurethane sealant from Sikaflex to ensure waterproofing. Additionally, I applied the same sealant around the base of the wall socket to prevent any moisture from entering.
The Outcome
Fast forward a year, and I’m thrilled to report that this setup has worked flawlessly. The Shelly 1 Minis have operated without any issues, even during harsh weather conditions. The Wi-Fi connection has remained stable, and the devices have performed as expected.
Lessons Learned
While the initial setup required some careful planning and execution, the results have been well worth the effort. Here are a few tips I’d like to share:
- Enclosure Choice: Opt for an enclosure with an IP rating suitable for your climate. This ensures your devices remain protected.
- Sealing: Don’t compromise on the quality of the sealant. A good seal can mean the difference between a successful installation and frequent malfunctions.
- Regular Checks: Even with the best setup, it’s wise to periodically inspect your installations, especially after extreme weather events.
This project has reignited my enthusiasm for smart home technology. It’s amazing how a little creativity and the right tools can turn even the most mundane tasks into something enjoyable and efficient. If you’re considering a similar project, I highly recommend the Shelly 1 Mini. It’s a testament to how reliable and versatile smart home devices can be, even in the most challenging environments.
Happy tinkering! ![]()
