I’ve been experimenting with integrating my Hörmann Liftronic Garage Door Opener with a Shelly 1 Plus to control it via my smartphone. The setup involved connecting the Shelly 1 Plus to a 230V power source and linking it to my existing garage door switch. Here’s how I did it:
Setup Overview
- Power Supply: I connected the Shelly 1 Plus to a 230V outlet, ensuring it has a stable power source.
- Input/Output Configuration: I wired the garage door switch to the Shelly’s I/O port, allowing it to trigger the door opener.
- Magnetic Contact Sensor Integration: To monitor the door’s status, I added an Abus MK2000W Magnetic Contact Sensor. This sensor detects whether the door is open or closed and sends updates to the Shelly app.
Challenges and Solutions
Initially, I faced a challenge with the magnetic sensor’s voltage rating. Since it’s designed for 100V, I was concerned about connecting it directly to the Shelly’s 230V supply. I solved this by using a 12V power adapter specifically for the sensor, ensuring it operates safely within its voltage range.
Tips for Others
- Voltage Matching: Always check the voltage requirements of your sensors and adapt accordingly.
- Placement: Position the magnetic sensor securely to ensure accurate readings.
- App Configuration: Spend time customizing the Shelly app to match your needs, such as setting up notifications for door status changes.
Conclusion
This integration has been a great addition to my smart home setup. It not only provides convenient control but also adds a layer of security by monitoring the garage door’s status. I’m excited to explore more automation possibilities with my Shelly devices!
If anyone has questions or suggestions, feel free to share your experiences!
