Shelly 1PM for Pump Monitoring: A Successful Setup
I’ve been exploring the world of smart home automation, and I’m thrilled to share my recent success with the Shelly 1PM for monitoring my water pump. Let me walk you through my journey and some tips I’ve picked up along the way!
The Challenge:
I wanted to keep an eye on my water pump to ensure it wasn’t running for too long, which could indicate a potential issue. The pump is controlled by a float switch, so I needed a reliable way to monitor its operation without constantly checking it manually.
The Solution:
After some research, I decided to go with the Shelly 1PM. It’s a compact device that can monitor energy usage and control a connected device via its relay. Here’s how I set it up:
  1. Installation:
    I installed the Shelly 1PM in my electrical panel, connecting it to the pump’s circuit. This allows it to monitor the pump’s power consumption.
  2. Configuration:
    Using the Shelly app, I set up a rule to notify me if the pump runs for more than 3 minutes. This threshold gives me enough time to check if everything is working as it should.
  3. Integration:
    I integrated the Shelly 1PM with my home automation system, so I receive notifications directly on my phone. It’s been a game-changer for peace of mind!
Tips for Others:
  • Placement Matters: Ensure the Shelly 1PM is placed in a location with stable power supply and minimal interference.
  • Test Before Relying Fully: After installation, test the setup by simulating different scenarios to ensure it works as expected.
  • Regular Check-Ups: Periodically review the energy usage data to detect any unusual patterns early.
A Little Story:
Just last week, the Shelly 1PM sent me a notification that the pump had been running for over 3 minutes. I quickly checked and found that the float switch needed adjustment. Without this setup, I might have come home to a flooded basement!
Final Thoughts:
I’m absolutely impressed with the Shelly 1PM’s reliability and the ease of integration into my smart home ecosystem. It’s a small investment that brings significant peace of mind. If you’re looking for a similar solution, I highly recommend giving it a try!
Thank you to the community for all the helpful discussions and troubleshooting tips that guided me through this project. Happy automating everyone! :rocket:
