Shelly 2.5 Roller Shutter Limitation and Time Synchronization Tips
Hey everyone, I wanted to share some insights about my experience with the Shelly 2.5 roller shutter controller. After setting it up, I noticed that the default calibration didn’t quite meet my needs, especially for partial opening. I did some research and found that you can manually adjust the travel time to limit the roller shutter’s movement to specific percentages, like 100% to 40%. This was a lifesaver for creating consistent partial openings without overcomplicating things. The Shelly app made it pretty straightforward to tweak these settings, and I haven’t had any issues since adjusting them. Another thing I wanted to mention is the time synchronization feature. I noticed that my Shelly devices occasionally fell out of sync, especially after power outages. I found that manually triggering a time sync through the app helps keep everything in order. If you’re experiencing similar issues, a quick restart or manual sync can work wonders. I’d love to hear how others are optimizing their Shelly setups or if there are any additional tips you’ve discovered. Let’s keep the knowledge flowing! :rocket:
