Shelly 4 Pro: A Smart Solution for Dimming and Compatibility
I recently made the switch from traditional Eltako switches to the Shelly 4 Pro, and I must say, it’s been a game-changer! :star2: I wanted to share my experience in case anyone else is considering this upgrade or facing similar challenges.
The Setup
I have four dimmable channels in my living room, each controlled by Eltako EUD12NPN-UC switches. The goal was to replace these with the Shelly 4 Pro to enable smart control via Alexa while maintaining compatibility with my existing wiring and switches.
Challenges and Solutions
Initially, I was concerned about whether the Shelly 4 Pro could handle dimming alongside the existing Eltako switches. After some research and experimentation, I found that it works perfectly! Here’s how I configured it:
  1. Input Configuration: Each input on the Shelly 4 Pro was set to detect the Eltako switches. This ensures that the existing wall switches still function as they always have.
  2. Output Configuration: I configured each output channel to handle dimming. This was crucial since not all my lights are LED, and I needed precise control over the dimming levels.
  3. Alexa Integration: Setting up Alexa was straightforward. The Shelly app made it easy to link each channel to Alexa routines, allowing me to control the lights with voice commands.
Tips for Others
  • Compatibility Check: Ensure your existing switches are compatible with the Shelly 4 Pro. Most standard switches should work, but it’s always good to double-check.
  • Firmware Updates: Keep the Shelly 4 Pro firmware updated. I noticed improved performance after the latest update.
  • Configuration Assistance: If you’re unsure about any settings, the Shelly community forums are a great resource. There are plenty of guides and user experiences to help you out.
Switching to the Shelly 4 Pro has been seamless and rewarding. It offers the best of both worlds—retaining the functionality of traditional switches while adding the convenience of smart home integration. If you’re looking to modernize your lighting controls without a complete overhaul, I highly recommend giving the Shelly 4 Pro a try! :bulb:
Happy smartening! :rocket:
