Hey everyone, I just wanted to share my recent experience with the Shelly 4 Pro and how it’s transformed my home lighting setup. As someone who’s been dabbling in smart home tech for a while, I’ve always been on the lookout for reliable and versatile devices, and the Shelly 4 Pro definitely fits the bill.A few weeks back, I decided to upgrade my living room lighting system. I had some Eltako dimmable switches that were working fine, but I wanted to integrate them into my smart home ecosystem for more convenience. After doing some research, I came across the Shelly 4 Pro and decided to give it a try.The installation process was surprisingly straightforward. I connected the Shelly 4 Pro to my existing wiring, and within minutes, I had it integrated with my Alexa setup. The dimming feature worked perfectly right out of the box, which was a huge relief. I was initially worried about compatibility issues, especially with different types of lamps, but the Shelly 4 Pro handled everything seamlessly.One thing I really appreciate is the ability to configure each output channel individually. I have a mix of LED lights and traditional bulbs, and being able to set each channel to either phase-in or phase-out was a lifesaver. This customization ensures that all my lights dim smoothly without any flickering or buzzing.I also wanted to share a quick tip for anyone considering the Shelly 4 Pro. If you’re using multiple input sources (like door sensors or wall switches), make sure to test the configuration thoroughly. I had a hiccup initially where one of my inputs wasn’t responding correctly, but after a quick firmware update and some tweaking in the Shelly app, everything worked perfectly.Overall, I’m thrilled with how the Shelly 4 Pro has enhanced my home automation setup. It’s reliable, easy to use, and offers the kind of flexibility that I was looking for. If you’re in the market for a smart dimmer, I highly recommend giving the Shelly 4 Pro a shot. Happy experimenting everyone! ![]()
