Shelly 4 Pro Installation and Community Support Experience
I recently decided to upgrade my home lighting system by replacing some old Eltako switches with the Shelly 4 Pro. At first, I was a bit concerned about the installation process, especially since the existing switches were only 55mm deep. I wasn’t sure if the Shelly 4 Pro, which is 57mm deep, would fit without major modifications to the electrical box. However, after some research and measurements, I realized it might just work!
I ordered the Shelly 4 Pro and started planning the installation. I was pleasantly surprised by how straightforward the setup was. The device came with clear instructions, and the Shelly app made it easy to configure everything. I was able to integrate it seamlessly with my existing lighting system, and the momentary switch setting worked perfectly with my existing wall switches.
What really impressed me, though, was the support I received from the community. When I shared my installation progress on the forum, several experienced users offered tips and reassured me that the setup was correct. One user even shared a detailed guide they had created for similar installations, which I found incredibly helpful.
Now that everything is up and running, I’m thrilled with how smooth the process was. The Shelly 4 Pro has added a whole new level of convenience to my home, and I feel confident knowing that I can tweak settings or troubleshoot issues with the help of this amazing community. If you’re considering upgrading your lighting system, I highly recommend giving the Shelly 4 Pro a try—it’s been a game-changer for me!
