Shelly Device Setup and Troubleshooting Tips
Hi everyone, I wanted to share my experience with the Shelly devices I recently installed in my home. While most of the setup went smoothly, I did encounter a few hiccups along the way that I thought might be helpful to others.
Initially, I noticed that my Shelly 1L and 2PM relays were causing some flickering issues with my smart LED bulbs. It was quite frustrating, especially since I was excited to transition from traditional switches to a fully automated system. After some research and trial and error, I discovered that the issue was related to how the neutral wires were connected in my 3-way and 4-way switch configurations.
The solution involved carefully separating the neutral wires from different circuits and ensuring that each Shelly device was powered by the correct circuit. For my 4-way setup, I had to borrow constant power from another circuit, which required a bit of careful wiring but ultimately resolved the flickering problem. It was a learning experience, but I’m glad I stuck with it!
I’d like to share a few tips for anyone else setting up Shelly devices:
  • Always double-check your wiring, especially in multi-circuit setups.
  • If you’re using detached mode, ensure that the devices have constant power.
  • Don’t hesitate to consult the community forums or reach out to Shelly support if you’re stuck.
Overall, I’m really impressed with how reliable and customizable the Shelly devices are. They’ve transformed my home automation setup, and I’m looking forward to integrating even more smart devices in the future. Happy tinkering everyone! :rocket:
