Shelly Devices and Zigbee Controller Integration Tips
Hey everyone! :wave: I’ve been diving into the world of smart home automation for a while now, and I thought I’d share some tips and experiences I’ve had with Shelly devices and Zigbee controllers. Whether you’re just starting out or looking to expand your setup, I hope this helps!
Shelly Devices in the New SmartThings App
I’ve noticed that some Shelly devices work perfectly in the old SmartThings app but don’t show up in the new one. This can be a bit frustrating, but I’ve found that updating the firmware often resolves the issue. Here’s how I do it:
  1. Firmware Update via Shelly App: I use the Shelly app to check for updates. Sometimes, the app says the device is updated, but the version remains the same. I’ve had success by manually downloading the latest firmware and updating through the Shelly app or directly via the device’s IP address.
  2. Direct OTA Update: If the Shelly app doesn’t work, I try accessing the device via its IP address in the browser and navigate to the OTA update section. This method has been reliable for me.
Zigbee Controller Configuration
I’ve been experimenting with a ConBee II Zigbee controller alongside my Philips Hue bridge. Initially, I faced some connectivity issues with my Zigbee devices. Here’s what I learned:
  1. Pairing Devices: Make sure your Zigbee devices are in pairing mode before adding them to your Zigbee controller. I’ve found that sometimes devices need a few attempts to pair successfully.
  2. Firmware Updates for Controllers: Keeping your Zigbee controller firmware up to date is crucial. I’ve noticed improved stability and device compatibility after updating the firmware.
  3. Network Topology: If you’re using multiple Zigbee devices, consider their placement to ensure a strong mesh network. I’ve had better luck placing devices closer together initially and then expanding the network.
General Tips
  • Backup Your Setup: Always back up your smart home configurations. I use the backup feature in my hub regularly to avoid losing my setup in case of a malfunction.
  • Test in Stages: When adding new devices, test them one at a time to identify and troubleshoot issues quickly.
  • Community Support: Don’t hesitate to reach out to forums like this one for help. I’ve found the community incredibly supportive and knowledgeable.
Smart home automation is such a rewarding endeavor, and with a bit of trial and error, you can create a seamless and efficient system. I’d love to hear about your experiences and any tips you’ve picked up along the way! :handshake:
Happy automating! :rocket:
