Shelly Devices Connectivity Issues in AVM Mesh
I’ve been trying to set up a Shelly 1 Plus and a Shelly 1 in my basement to control some lights, and while they work perfectly when connected via a physical switch, the WLAN connectivity is giving me quite a headache. I’m using a Fritz!Box 7590 AX with several AVM Repeaters in LAN-Bridge mode. Both the 2.4 GHz and 5 GHz networks share the same SSID, and there’s a repeater in the same room as the Shelly devices. However, the Shelly devices keep connecting to the main Fritz!Box station, which is much farther away, causing frequent disconnections or unreachability. Strangely, all other non-Shelly devices on the same network stay connected without any issues. I’ve tried adjusting the network settings and ensuring the Repeaters are optimally placed, but the problem persists. Has anyone encountered a similar issue or has any tips to resolve this? Any advice would be greatly appreciated! :pray:
