Shelly Dimmer 2: Maximizing Brightness and Smoothing Transitions
Hey everyone, I just wanted to share my experience with the Shelly Dimmer 2. I recently purchased one to control my LED lights, and while it’s been a fantastic addition to my smart home setup, I did run into a couple of minor issues that I thought I’d work through and share with the community.
First off, I noticed that the dimmer didn’t allow me to set a maximum brightness level. My LEDs reach full brightness around 70% on the dimmer, which was a bit confusing at first. I ended up experimenting with the settings and found that manually adjusting the brightness curve in the Shelly app made a huge difference. Now, the transition from dim to bright is much smoother, and I don’t have to worry about the lights being too harsh when they reach full brightness.
Another thing I wanted to mention was the slight delay I noticed when adjusting the brightness manually. I reached out to the community and found that others had similar experiences. One user suggested adjusting the dimmer’s response time settings, which I did, and it significantly reduced the lag. It’s such a small tweak, but it makes a big difference in the overall user experience.
Overall, I’m really happy with the Shelly Dimmer 2. It’s versatile, easy to set up, and has already added a lot of convenience to my home. If you’re thinking about giving it a try, I’d say go for it—it’s definitely worth exploring!
I’d love to hear how others are using their Shelly Dimmer 2s or if anyone has any tips or tricks they’d like to share. Let’s keep the conversation going! :bulb::sparkles:
