Shelly Dimmer 2: Setting Up Multi-Switch Automation
Hey everyone, I’ve been diving into the world of smart home automation lately, and I wanted to share my experience with setting up the Shelly Dimmer 2 for multiple switch configurations. I’ve been using this device to control dimmable lights in my home, and it’s been a fantastic addition to my setup. However, I ran into a bit of a challenge when trying to configure it for multiple switches. Let me walk you through how I tackled this and what I learned along the way.
Initially, I wanted to use a pair of double switches (without any detent mechanism) to control a single dimmable light. The idea was to have one switch control the on/off state and the other handle the dimming. I thought it would be straightforward, but I quickly realized that the configuration wasn’t as simple as I hoped. After some research, I came across some helpful guides and forum posts that provided clarity.
One thing I discovered is that the Shelly Dimmer 2 supports multiple switch configurations, which is perfect for my use case. I learned that I could configure each switch to handle specific actions, such as turning the light on/off or adjusting the brightness. This meant I could set up one switch to control the on/off state and another to handle the dimming, just as I had envisioned.
To make this work, I had to delve into the device settings and experiment with different configurations. I found that the Shelly app made it relatively easy to set up these actions, but it required a bit of trial and error to get everything just right. I also appreciated the ability to customize the switch behavior, which allowed me to tailor the setup to my specific needs.
After some time spent tweaking the settings, I finally got everything working smoothly. The double switches now function perfectly, with one controlling the on/off state and the other handling the dimming. It’s a simple yet effective setup that adds a nice touch of convenience to my home.
If you’re considering using the Shelly Dimmer 2 for a similar setup, I’d recommend taking the time to explore all the configuration options available. The device is incredibly versatile, and with a bit of experimentation, you can create a custom automation solution that perfectly suits your needs. I’m really happy with how this project turned out, and I’m excited to continue expanding my smart home setup in the future.
Cheers,
