I recently set up a Shelly 2 Dimmer and wanted to share my experience and some tips for those who might be new to this device. The Shelly 2 Dimmer is a fantastic addition to any smart home setup, offering both brightness control and temperature monitoring via MQTT. However, getting everything working smoothly can be a bit tricky, so here’s what I learned along the way.
First, I connected the Shelly Dimmer to my MQTT broker and was surprised at how responsive it was. The brightness control is incredibly smooth, and the temperature readings are accurate. However, I noticed that the default MQTT topics didn’t include some of the attributes I wanted to use, like the brightness level. After some research, I discovered that I could customize the MQTT topics in the Shelly app to include additional attributes. This was a bit of a learning curve, but it made the integration with my home automation system much more seamless.
Another thing I found useful was the ability to set up scenes and automations using the Shelly app. For example, I created a scene where the lights dim to 50% at sunset and then fully turn off after an hour. This has been a great way to save energy without sacrificing comfort. I also experimented with geofencing, so the lights automatically adjust based on whether I’m at home or away. It’s amazing how much you can do with just a few settings!
One challenge I faced was ensuring the Shelly Dimmer was compatible with my existing smart home ecosystem. I had to tweak some settings in my MQTT broker to ensure smooth communication, but once everything was set up, it worked like a charm. I also found that the Shelly Dimmer works perfectly with voice commands through Alexa, which adds another layer of convenience.
For anyone looking to install a Shelly Dimmer, I’d recommend starting with the basics—connecting it to your MQTT broker and setting up simple automations. Once you’re comfortable with the basics, you can explore more advanced features like custom scenes and integration with other smart devices. The Shelly community is also very active and helpful, so don’t hesitate to reach out if you run into any issues.
Overall, I’m really happy with the Shelly 2 Dimmer. It’s a reliable and versatile device that has significantly improved my smart home experience. If you’re considering adding a dimmer to your setup, I highly recommend giving the Shelly 2 Dimmer a try!
