Shelly Dimmer2 Calibration and Smart Lighting Setup
Hey everyone, I wanted to share my recent experience with setting up the Shelly Dimmer2 in my home. I’ve been into home automation for a while, but this was a new challenge for me. A couple of weeks ago, I installed two Shelly Dimmer2 units to control my living room lamps. The first lamp worked perfectly right out of the box—calibration went smoothly, and I could adjust the brightness without any issues. However, the second lamp was a bit of a puzzle. Despite the Shelly app indicating successful calibration, the dimmer didn’t respond as expected. When I set it to 100%, the lamp would draw too much power and turn off immediately! After some trial and error, I realized the optimal setting was around 50%.I reached out to the community for advice and discovered that manual calibration was the solution. By adjusting the min and max values in the Shelly settings, I was able to fine-tune the dimmer to work perfectly with my lamp’s transformer. It was a bit tricky, but with some guidance from the forums, I got it sorted out.This experience taught me the importance of understanding your hardware’s specifications and not being afraid to dive into manual settings. The Shelly Dimmer2 is a fantastic device, and with a little tweaking, it can integrate seamlessly into any smart home setup.If anyone else is having similar issues, I’d be happy to share my calibration settings or troubleshoot together. Happy automating! :rocket:
