Shelly i4 Connectivity Issue: Troubleshooting and Insights
I recently encountered a puzzling issue with my Shelly i4, and I wanted to share my experience and resolution in case it helps others facing similar problems. Here’s my journey through this troubleshooting process:
The Problem
Everything was working smoothly with my Shelly i4 until one day, the buttons suddenly stopped sending payload messages to Node-Red. Despite the Shelly web interface showing activity when buttons were pressed, Node-Red wasn’t receiving any data. I was initially baffled since the setup had been functioning perfectly before.
Initial Troubleshooting Steps
  1. Device Restart: I restarted both the Shelly i4 and Home Assistant to rule out any temporary glitches. Unfortunately, this didn’t resolve the issue.
  2. Mosquitto Broker Check: I checked the Mosquitto broker logs to ensure messages were being published. The broker confirmed that messages were indeed being sent, as evidenced by the online status messages.
  3. Node-Red Flow Review: I verified that the Node-Red flow was correctly configured and connected. The node was active, but no payloads were being received.
  4. Web Interface Activity: Pressing the buttons on the Shelly i4 showed activity in the web interface, confirming that the device itself was functioning correctly.
The Solution
After some research and further troubleshooting, I discovered that the issue was related to a recent update in the Shelly firmware. The update had inadvertently changed how payload messages were formatted, causing Node-Red to fail in parsing them correctly. To fix this, I:
  1. Updated Node-Red Flow: Adjusted the flow to accommodate the new payload structure.
  2. Reconfigured MQTT Topics: Ensured that all topics were correctly subscribed to and that the payload parsing matched the updated format.
Key Insights
This experience taught me the importance of staying updated with firmware changes and being adaptable with configurations. It also highlighted the value of thorough logging and testing when troubleshooting connectivity issues.
While the issue was initially frustrating, it provided a valuable learning opportunity. I’m now more confident in handling similar problems in the future. If anyone else is facing connectivity issues with their Shelly devices, I recommend checking for firmware updates and reviewing your flow configurations. Happy troubleshooting! :rocket:
