Shelly Plus 1: Firmware Downgrade and Camera Connection Tips
Hello everyone, I’ve been diving into the world of Shelly devices and wanted to share my experiences and some tips I’ve picked up along the way. I recently ran into an issue with my Shelly Plus 1 where the firmware update to version 0.12.0 caused my MQTT connection to malfunction. It was quite frustrating because all I received were ‘RSSI’ and ‘Uptime’ values, leaving me in the dark about the actual sensor readings. After some research, I discovered that downgrading the firmware was the solution, but it wasn’t a straightforward process. I’d love to hear if anyone else has encountered similar issues or has tips on safely downgrading firmware without losing functionality.
Another topic I’d like to discuss is the camera connection problems some users have faced. I came across a post where a user mentioned that one of their cameras wouldn’t connect to the hub without a battery. The blue LED would flash indefinitely, and resetting the camera didn’t resolve the issue. I wonder if there’s a common fix for this or if it’s a hardware-specific problem. Has anyone else experienced this and found a workaround?
On a more positive note, I’ve been impressed with the versatility of Shelly devices. For instance, using the Shelly 1 Plus with temperature sensors has been a game-changer for monitoring different heating and solar lines in my home. I’ve set up notifications through the app to alert me when specific temperature thresholds are reached, which has been incredibly helpful for maintaining optimal heating levels. If anyone has tips on customizing these notifications further or integrating them with other smart home systems, I’d love to hear about it!
Lastly, I’m curious about others’ experiences with integrating multiple brands of smart devices. I’ve been trying to consolidate my setup but find it challenging to get everything to work seamlessly. Are there any tools or apps that have made this process easier for you? I’d appreciate any recommendations or success stories!
Thanks for reading, and I look forward to hearing your thoughts and experiences!
