Shelly Plus 1 Setup with Gira Switch - A Smooth Experience
I recently set up my Shelly Plus 1 without using Eltako, relying solely on a Gira switch to control a light. Initially, I was a bit puzzled about how to configure everything properly, especially since some menu options mentioned in older threads seemed to have changed with the latest firmware. But after some research and trial, it worked out perfectly!
Here’s what I did:
  1. Firmware Check: Ensured my Shelly Plus 1 was running the latest firmware. Updates are so crucial for optimal performance!
  2. Switch Configuration: Connected the Gira switch directly to the Shelly. The setup process was straightforward—just a matter of selecting the right mode in the Shelly app.
  3. Testing: Pressing the switch once toggles the light on or off. It’s responsive and reliable, even when the Home Assistant system is offline. That peace of mind is invaluable!
Pro Tip: If you’re using older firmware, consider updating first. It streamlined the entire process for me. The Shelly app also has some fantastic visual guides that really help in understanding the setup流程.
I’m thrilled with how seamless this integration turned out. It’s a great example of how legacy switches can coexist beautifully with modern smart home tech. If anyone has questions or needs a step-by-step guide, feel free to ask—I’d be happy to share my configuration screenshots and settings!
