Hi everyone, I wanted to share my recent experience integrating the Shelly Plus 1PM Mini with the Wall Display. It’s been a journey of discovery, and I thought I’d document it for anyone else who might be considering this setup.
I’ve been a fan of Shelly devices for a while now, and the Plus 1PM Mini seemed like the perfect addition to my smart home setup. Its compact design and multiple functionalities made it a no-brainer for my needs. However, I wanted to take it a step further by integrating it with a wall display for a sleek, seamless look.
The Setup Process
I started by installing the Shelly Plus 1PM Mini in my living room. The installation was straightforward, and the device paired effortlessly with my existing network. The next step was connecting it to the wall display. I was excited to see how smooth this integration would be.
The Challenge
While the Shelly device worked perfectly through the app, I encountered an issue when trying to control it via the wall display. No matter how many times I pressed the button, nothing happened. At first, I thought it might be a firmware issue, so I updated both the Shelly device and the wall display to the latest versions. Unfortunately, the problem persisted.
The Solution
After some research and trial and error, I discovered that the issue was with the configuration settings on the wall display. I had to manually adjust the input settings to ensure compatibility with the Shelly device. Once that was sorted out, everything worked like a charm!
Tips for Others
If you’re planning to integrate your Shelly devices with a wall display, here are a few tips I’ve learned along the way:
- Check Compatibility: Ensure that both your Shelly device and wall display are compatible with each other.
- Firmware Updates: Always keep your devices updated to the latest firmware to avoid any potential issues.
- Configuration Settings: Don’t hesitate to tweak your wall display settings if you encounter any problems. Sometimes, a simple adjustment can make all the difference.
Overall, my experience with the Shelly Plus 1PM Mini and the wall display has been overwhelmingly positive. The device is reliable, easy to use, and the integration with the wall display adds a touch of elegance to my smart home setup. I’m already brainstorming ways to expand this integration further in the future.
If anyone has any questions or needs advice on setting up their Shelly devices, feel free to reach out. I’d be happy to help! ![]()
