Thank you for providing an update on that!
@absent and I began debugging the device to provide Zigbee2MQTT support. The current progress is available on GitHub ( https://github.com/absent42/fp300 ). All sort of contributions are welcome.
I bought the Aqara M100 hub on Amazon. Once I connected the FP300 to the hub I could update the firmware. I don’t know if I could have done that via Apple Home. I’ve been enjoying it. It’s much simpler than the FP2. It’s kind of plug and play. I have it in a small bathroom and it has been working well. The FP2 was a little over powered for my use case.
I’m sorry, but I put my review in a seperate post. Below are my comments:
At the start of the year, my home was filled with a variety of smart devices from different vendors, each with its own connectivity requirements. This setup led to duplicative automations throughout my home, making things more complicated than they needed to be. But after receiving and testing the Aqara FP300, I’m realizing it’s time to rethink my entire smart home strategy.
Compact and Discreet: The small, unobtrusive design of the FP300 is a game-changer. Holding it in my hand gave me a completely different perspective compared to seeing it online. I expected it to be larger, but its compact size makes it easy to place anywhere without drawing attention. It seamlessly blends into any room.
Easy Setup: Installation was a breeze. The sensor integrates effortlessly with the Aqara Hub, and the magnetic mounting option is a huge plus. It allows me to move the sensor between rooms with minimal effort during testing. Plus, its cable-free design gives me the freedom to place it almost anywhere without worrying about power sources.
Automation-Ready: The FP300 excels in creating custom automation routines. After setting it up on my Aqara hub, I quickly ran through several automations, all of which performed flawlessly. Curious about compatibility, I removed it from the Aqara hub and added it to my SmartThings hub. Since it’s a Matter device, the integration was seamless, and the testing results were equally impressive.
Versatility and Value: What truly stands out is the FP300’s capability. With just this one device, I’ve replaced the need for separate motion, light, and temperature sensors. It’s a perfect example of how a single device can streamline and simplify a smart home setup.
Final Thought: Overall, the Aqara FP300 is an excellent, cost-effective solution for anyone looking to enhance their smart home with motion detection and automation. It’s reliable, versatile, and makes managing your home more efficient than ever. I can’t wait for production and roll out. I will be purchasing several more for other areas of my home.
I can confirm this converter is working with most of the functions. I have no coding experience but after quick testing I’m amazed by response times and stability of presence detection. I will test object tracking functionality in the next few days. I can’t contribute to code but I will share experience and logs if needed.
How Is the product?
Grate thax
I received the Aqara FP300 presence sensor just a few days ago, and even with such a short testing period, I couldn’t be more satisfied. When I first opened the package, I was honestly surprised by the size of the sensor’s box, quite remarkable and impressive at the same time. The sensor itself feels premium, built with high-quality materials.
I want to sincerely thank @AqaraOfficial for the opportunity to test this new sensor ahead of its official release and congratulate them on creating such an excellent product.
I added it to my smart home setup and installed it on the wall in my office. Visually, it looks fantastic, very compact and discreet, blending effortlessly into the room without being obtrusive. Its small size really helps maintain a clean aesthetic.
(Just for fun: can you spot the FP300 in the image? It’s definitely there, but its tiny and discreet design makes it a real challenge — that’s how small it is!)
Right away, as I started exploring the configuration options, it became clear this device is a true step forward in presence sensing technology. The ability to disable specific features and customize detection intervals for temperature, humidity, and light really makes sense because it allows adapting the device to individual user needs and different spaces.
Previously, I had a problem on the days I worked from home. Since I was in the office those days, the light would turn off because the sensor failed to detect my presence properly while I was sitting still at my desk. This sensor solved that issue perfectly, allowing my automation to work smoothly without interference.
I am seriously considering replacing all my conventional motion sensors with these. The battery-powered design makes it extremely easy to install anywhere, which is a real game changer.
Moreover, it allowed me to replace two sensors with just one: combining motion detection and temperature/humidity sensing, plus adding presence detection via mmWave technology. Simply incredible.
I’m excited to get more units for the rest of the rooms in my home. This sensor has truly impressed me from the start and looks to be a massive upgrade for smart home automation.
I’m interested.
I think missed it
Late update: FP300 should now be working in Zigbee2MQTT without an external converter (v2.6.2 - Release 2.6.2 · Koenkk/zigbee2mqtt · GitHub )
I’d be delighted to be considered.
I just acquired the FP2 and am about to try it out. A comparison would be perfect.
Correct unfortunately
The FP300 is much simpler to use. It doesn’t include the capability to do zones, so the FP300 is best for simple areas. I switched from the FP2 to the FP300 in my small bathroom. I no longer have the ghost problem that I occasionally had with the FP2. You need to have an Aqara hub if you want the FP300 to show up in the Aqara app. With the FP2 I didn’t need a hub.
Hello guys,
Can you show me all the entities you saw when you integrate the FP 300 with Zigbee2Mqtt directly on Home Assistant ?
I wonder if there is more entities than I get in Matter over thread without Aqara hub.
I would prefer the plug of the FP2 over the wireless FP3 with no zones & other features the FP2 has.
There are more features that work through the zigbee protocol, the matter protocol has less features on the FP3.
Hello, when we will see this sensor on sale?
What would be the method for a full factory reset?
Thank you
Konečne som sa dostal k zapojeniu snímača. Čo sa týka jeho vyhotovenia, tak je vidieť že sa jedná ozaj o kvalitný výrobok. Zapojenie a inštalácia prebehla úplne bez problémov. Čo sa týka automatizácie, tak ja som sa rozhodol snímač používat zatiaľ prednostne k svetelnej automatizácii. Táto síce pracuje spoľahlivo, no keďže snímač nepodporuje rozdelenie miestnosti do jednotlivých zón, alebo to len ja zatiaľ neviem nastaviť, tak môžem vytvoriť automatizáciu len k jedinému vypínaču🙈. A to kôli tomu senzoru som vymenil komplet všetky vypínače v byte🙈 Uvítal by som autualizáciu softwaru snímača kde by bola možnosť po načítaní miestnosti, túto rozdeliť na jednotlivé zóny v ktorých by sa následne dalo jednotlivo nastavovať automatizácie.
