Shortcut to disable detection on G4 cam
Hi. I own two G4 cams.
One as doorbell in Germany, one as surveillance cam inside an apartment in Spain.
The problem: IFTTT is not working, and geofence with an automation also not.
Switching to home mode or disarm does not help either.
So whenever I come home, I have to cover the camera with a cap in order to not being recognized walking by every minute.
Why is there no shortcut to disarm a specific cam manually like the ring doorbell offers it in the homescreen?
Thx,
Mike
Perhaps you could setup an automation that disables the detection, you could then associate this to either a button press or a shortcut to the automation on your phone?
Thank you for your reply. I already tried the automation with the GPS location and to change the camera into home or away mode when arriving or leaving. I also tried the disarm mode. The problem is that basic guard is not deactivated so I’m still recognizing when I’m moving around in the apartment.
Mike
