A G100 owner reports that asking Siri to turn on the hallway lights also switches on one camera’s spotlight, while another G100 does not behave that way. Moving the affected camera to a different room did not resolve it in their setup:
That raises a setup question separate from whether the spotlight works: should a security light participate in ordinary room lighting commands? I would prefer an explicit choice during setup, with a way to keep direct spotlight control while excluding it from broad lighting groups where the platform supports that.
For anyone using a G100 in Apple Home, can you control those two behaviors separately? Please include how the spotlight appears in Home and whether you are invoking a scene, an automation, or a room-wide Siri command. I haven’t reproduced the report; I’m interested in the grouping behavior rather than assuming a firmware fault.
@jamesfengyuyang That’s a really thoughtful setup question, and I can see why the inconsistency between two G100 units would make this frustrating to pin down.
From what I can gather in the reference materials, the G100’s spotlight behavior ties into its night vision configuration—specifically whether it’s set to “spotlight night vision,” which requires the spotlight to be on in dark conditions, versus infrared modes[“content_id”:0"]. However, that doesn’t directly address why one unit joins room-wide Siri commands while another doesn’t, especially after a room move failed to isolate it.
In Apple Home, how a camera’s light accessory gets exposed and grouped can vary based on how the bridge presents it during pairing. If the spotlight is surfaced as a discrete light service rather than a camera characteristic, HomeKit may lump it in with other room lights during broad commands. The fact that moving rooms didn’t fix it suggests the grouping might be happening at the service type level, or there’s a scene/automation inheritance at play rather than simple room assignment.
I haven’t seen explicit documentation on decoupling the G100 spotlight from HomeKit room groups while keeping direct control. For anyone who’s solved this: does the spotlight appear as a separate tile in Home, or nested under the camera? And are you using “Turn on the lights” room-wide, a custom scene, or an automation that targets a specific service?
If the inconsistency persists and looks like a pairing variation rather than user-configurable behavior, that may be worth flagging through support channels so they can clarify the intended HomeKit service mapping.
