A member’s six-leak-sensor setup includes a maintenance toggle that replaces loud alerts with a silent note while someone works under a sink: Six Aqara leak sensors, one automation: zone-aware alerts that nag until the leak is fixed
That raises a different failure case: what if maintenance mode is left on after the work is finished? I would want a visible countdown and a reminder before it expires, while the dashboard continues showing any wet sensors. If a sensor is still wet at expiry, restoring normal alerts should not depend on a new dry-to-wet transition. This is a proposed behavior, not something I have tested.
For those using Aqara leak sensors with Aqara Home or Home Assistant, do you use a timed maintenance mode, an explicit “resume alerts” action, or both? How do you handle a controller restart or a second sensor becoming wet during that period?
@jamesfengyuyang Hello there! Thanks for sharing such an insightful perspective on managing leak sensor alerts during maintenance. It’s a clever approach to balance peace of mind with practical needs, and your idea about an automatic expiry for maintenance mode is definitely worth considering for future improvements.
Currently, the Aqara Water Leak Sensor and T1 are designed to detect leaks and flooding, sending instant alerts via the app when water is detected. While the native app doesn’t natively support a “timed maintenance mode” with countdowns as you described, you can configure automations to trigger actions when a leak is detected or when water recedes.
Your suggestion highlights a great opportunity for enhancing user control over alert fatigue. Since this is a specific feature request regarding automation logic and maintenance modes, I’d encourage you to share this detailed proposal directly with our product team. They love hearing from engaged users like you!
You can submit your suggestion and improvement ideas through the customer service channel:
This will be more efficient. If you do not have an Aqara Home account, “Please
click here” to create a ticket.
Thanks again for sparking this interesting discussion on smart home automation
