After spending considerable time working with Home Assistant’s Modbus integration, I’ve noticed a few areas where the user experience could be significantly enhanced. Currently, writing to Modbus registers requires either using the Modbus service or creating custom scripts, which can be quite cumbersome for those looking to streamline their setup.
I propose a feature where the integration handles write operations more intuitively. By specifying the register, its type, and read-write capabilities in the configuration, users could modify the corresponding entity value directly within Home Assistant. This change would eliminate the need for additional scripts and make the process far more user-friendly.
Additionally, incorporating conversion options directly into the configuration would add a layer of flexibility. For example, if a register contains values like 1, 2, and 3, users should be able to map these to different modes in the YAML. This would allow the entity to display the converted values, enhancing customization without complicating the setup.
While I understand that some features might have lower priority, simplifying write operations is a must-have improvement. I’ve spoken to numerous individuals who face challenges with the current setup, and this change would address a common pain point effectively.
I’m eager to hear your thoughts and see this enhancement come to life. Let’s work together to make Home Assistant even more accessible and user-friendly for everyone!
