Simplifying Wireless Access to Your Security System
After experimenting with various setups for wireless access to my security panel, I wanted to share a solution that might be easier for those who aren’t as comfortable with Linux or complex configurations. I started with an AD2USB connected directly to my Vera system, which worked well. Then, I tried using an RPI as a USB-to-wifi bridge, but that required a good deal of technical expertise to get running smoothly. While I’m comfortable with Linux and networking, I realized not everyone might be. That’s why I explored alternative solutions.
I’ve found the Envisalink 3, combined with a low-cost wifi adapter like the Netgear WNCE2001 or the TPLink TP-WR703N, to be a solid choice. It eliminates the need for an RPI and provides a reliable, plug-and-play solution. The Envisalink 3 uses ethernet, making it ideal for installations where the Vera is located some distance from the security panel. The setup is entirely menu-driven, which makes it user-friendly and straightforward.
The total investment for the Envisalink 3 plus a wifi adapter was around $130, and it took about an hour and a half to get everything up and running (excluding labeling zones). This setup also allows for monitoring and control through the Envisalink/Eyez-on Internet portal, providing an alternative to Vera if needed. While the AD2USB is a great product, its reliance on USB can be a limitation for some installations. In contrast, the Envisalink 3 offers a more robust, plug-and-play experience for those looking for simplicity and reliability.
I hope this分享 helps others find a solution that works well for their setup without the need for extensive technical knowledge. If you’ve tried similar setups or have questions about integrating different systems, I’d love to hear your experiences or suggestions!
