Smart Alarm System Setup with Google Assistant and Home Assistant
Hey everyone! I’ve been working on setting up a smart alarm system using Google Assistant and Home Assistant, and I wanted to share my experience in case it helps anyone else. :star2:
My Setup:
I decided to go with a Hue switch integrated with Home Assistant. The goal was to have Google Assistant handle the voice commands, which would then trigger my Sonos speakers to play an alarm. The lights in my room would also turn off to help me sleep better. Simple, right? :blush:
The Challenges:
At first, it was a bit tricky getting everything to communicate properly. I had to figure out how to link Google Assistant with Home Assistant and ensure the Sonos speakers would play the alarm consistently. There were a few hiccups, like the lights not turning off immediately or the alarm not stopping as expected, but persistence paid off! :muscle:
The Solution:
I ended up creating a custom automation in Home Assistant. Here’s a quick rundown of what I did:
  1. Voice Command Integration: I set up Google Assistant to recognize specific commands like, “Hey Google, set my alarm for 7 AM.”
  2. Light Automation: I programmed the Hue switch to turn off the bedroom lights when the alarm goes off.
  3. Alarm Sound: The Sonos speakers were configured to play a soothing .mp3 file on repeat until the alarm is dismissed.
  4. Dismissal: I added a feature where saying, “Hey Google, stop the alarm,” would turn the lights back on and stop the music.
Tips for Others:- Test Each Component: Before setting up the full automation, test each device individually to ensure they work as expected.- Use Simple Commands: Start with straightforward voice commands and gradually add complexity as you get comfortable.- Check Logs: If something doesn’t work, check the logs in Home Assistant for any errors or clues.Final Thoughts:
It’s amazing how much smoother my mornings have become with this setup. I no longer fumble for my phone in the dark, and the gradual lightening of the room helps me wake up more naturally. If anyone has questions or needs help setting something similar up, feel free to reach out! :hugs:
Happy automating! :rocket:
