Smart Aquarium Automation Project
Hello everyone! I’m new to the world of smart aquariums and I’m looking for some advice on automating my setup. I have a small aquarium with a heater, UV light, and an IR heater, and I want to automate their operation based on temperature and light conditions. Here’s what I’m thinking:
  1. Heating and Temperature Control: I want the heater to maintain a consistent temperature, especially during colder months. I plan to use a temperature sensor to monitor the water and adjust the heater accordingly. I’m considering using a Shelly Plus 1PM for this, but I’m not sure if it can handle the analog temperature input.
  2. UV and IR Lighting: The UV light should turn on during daylight hours to mimic natural conditions, while the IR heater should regulate the temperature both day and night. I’m thinking of using a light sensor to trigger the UV light and an IR sensor for temperature adjustments. However, I’m unsure how to integrate these sensors with my current setup.
  3. Automation and Scheduling: I want everything to be automated, with the lights turning on and off at specific times and the heaters adjusting based on temperature readings. I’m also considering setting up a schedule for feeding times using a smart feeder. Does anyone have experience with integrating multiple sensors and devices for aquarium automation?
  4. Device Compatibility: I’m using a combination of Shelly devices and a Hubitat hub. Will these devices work seamlessly together, or do I need additional adapters or converters? I’m also wondering if there are any specific apps or integrations that can help me manage all these devices more efficiently.
  5. Safety and Reliability: Since this is a critical environment for my fish, I want to ensure that the automation system is reliable and failsafe. Are there any best practices or redundancies I should implement to prevent any issues? For example, what happens if the light sensor fails or the temperature sensor malfunctions?
I’m really excited about this project and can’t wait to get everything set up. Any advice or recommendations would be greatly appreciated! Let me know if you’ve tackled a similar project or have any tips to share. Thanks in advance!
