Hey everyone! I wanted to share my journey of setting up a smart aquarium using Homey. It’s been an incredible experience, and I hope this guide can help others who are looking to automate their aquariums as well.
The Setup
I started by identifying the key components needed for a smart aquarium. Here’s what I ended up using:
Fibaro Universal Binary Sensor: This measures water temperature with two water-resistant sensors. If the temperature goes out of the desired range, Homey alerts me via LaMetric, Push, and Neo Coolcam siren. LaMetric also displays the temperature hourly as a status update.
3x 433 MHz Relays: These control the operation of two air pumps and a CO2 valve. The CO2 valve is turned off at night to maintain optimal conditions.
3x Fibaro Wall Plugs: These are connected to the filter and heater. Homey monitors their operation, and if any component fails (e.g., the wattage drops below a critical threshold), Homey sends an alert.
Fibaro RGBW Controller and Flush RGBW Dimmer: These control 8 LED RGBW panels, allowing for beautiful lighting effects. From storm simulations to realistic sunrises and sunsets, the possibilities are endless!
3x Neo Coolcam Water Leak Detectors: These monitor the tank’s integrity and trigger an alarm if any leaks are detected, also turning off the pumps to prevent further damage.
Trust 433 MHz Remote Switch: This is used to manually turn off components during water changes or maintenance.
Neo Coolcam Door Contact: Alerts me if the tank’s enclosure doors are opened.
Mi Flora Sensor: While primarily designed for plants, I repurposed it to measure light levels in the aquarium. The fertilizer measurements are used to gauge nitrate levels and determine when a water change is needed.
The Experience
Setting up this system was a bit challenging at first, especially getting all the sensors and relays to communicate seamlessly. However, once everything was in place, the results were stunning. My fish are thriving in an environment that’s both beautiful and meticulously monitored.
Tips for Others
- Start Small: Begin with a few key components and gradually add more as you become comfortable with the system.
- Regular Maintenance: Even with automation, regular checks are essential to ensure everything is running smoothly.
- Experiment with Lighting: The RGBW panels are a game-changer. Don’t be afraid to experiment with different lighting schedules to create the perfect ambiance.
Challenges and Solutions
One of the biggest challenges was ensuring all devices were compatible with Homey. Some devices required additional setup or custom integrations. However, the Homey community forums were incredibly helpful in troubleshooting these issues.
This project has been a labor of love, and I’m thrilled with the results. It’s not just about automation; it’s about creating a harmonious ecosystem where my fish can flourish. I hope this guide inspires others to explore the world of smart aquariums!
If anyone has questions or needs advice, feel free to reach out. I’m happy to help!
Cheers,
Helmut
