Smart Automation: Automating Bathroom Fan Shutdown for Energy Efficiency
Hey everyone! I wanted to share my experience with setting up an automation in my bathroom to turn off the fan after the humidity drops, which has been a fantastic energy-saving solution. I’ve been using this setup for a few weeks now, and it’s been working like a charm!
The Setup
I have a Zigbee temperature/humidity sensor in my bathroom, along with a Zigbee-controlled fan. The idea was simple: turn the fan on when the light is switched on, and keep it running until the humidity level drops back to its original state. This ensures that the fan runs just long enough to clear the steam after a shower, without wasting energy.
Challenges and Solutions
At first, I struggled with creating the right automation. I started with a basic rule: if the humidity goes above a certain threshold, turn on the fan. But I wanted it to turn off automatically once the humidity returned to normal. After some research and trial and error, I figured out how to track the initial humidity level when the light is turned on. This way, the fan stays on until the humidity drops back to that baseline.
How It Works
  1. Trigger: The automation starts when the bathroom light is turned on.
  2. Action: The fan turns on immediately.
  3. Condition: The system monitors the humidity level.
  4. Completion: Once the humidity returns to the initial level, the fan turns off automatically.
Benefits
This setup has been a game-changer for me. It not only saves energy but also ensures that the bathroom stays dry and mold-free. Plus, it’s one less thing I have to remember to do manually!
Tips for Others
If you’re looking to set up something similar, here are a few tips:
  • Start Simple: Begin with a basic automation and gradually add more conditions as you get comfortable.
  • Test Thoroughly: Make sure to test each part of your automation to ensure everything works as expected.
  • Adjust as Needed: Don’t hesitate to tweak your settings based on how it performs in real use.
I’d love to hear how others have automated their homes for efficiency and convenience. Have you set up any interesting automations lately? Let’s share and learn together!
Happy automating! :rocket:
